904 to 999
63dartman
rio rancho, nm
Is it worth the effort to swap from a 904 to a 999. I saw a a999 on craigslist for 150 and needs rebuilt and comes with converter. Pics look good though.
ok..999 will give you 5 disc clutch pac...steel plantaries, and maybe 2.74/1.54 gear set...
what engine in what car are you using?
I have an article on doing an overdrive swap for the A518 trans if you like.Pm me with an addy and I'll send it.
Not interested in a overdrive swap. I don't want to cut up my tunnel. It's a 63 dart with a 360 pre magnum roller.
I believe the a999 uses an electronic lock-up torque converter. If so, it is not possible to create a torque converter with the small knob to fit the small pilot hole in the '63 slant six crank.
Been there; done that.
You'll need to change the crank out & replace it with a '68 or later forged crank.
Also, the tail shaft housing is larger in diameter, requiring ether cutting the trans tunnel or modifying the cross-member to lower the back of the transmission, which might require playing with pinion angles.
To keep the push button control for the later linkage transmission, you'll need to send your push button gear selector assembly to Imperial Services (http://www.imperialservices.net/) and purchase their conversion kit.
If you want this badly enough, it's worth the effort.
--Walt Jackson
