bobscuda67
Hi guys, I have a 340 67 cuda putting out about 300-325 horse with a 323 rear gear. I am building a 904 for it. I have a low gear set for it and a hemi governer Trans-go shift kit, 4.2 kickdown lever. Will the 4 clutch high gear drum will it live or will it have to be changed to a 5 clutch unit ? If so ,will the front pump need to be changed to a later one? What type of bands should I use? The car is street driven with 3 or 4 passes per season.
