904 trans id #s
MOBodyman
South Central MO
Can you tell which small block motor (& what year) was in front of this trans using these numbers below the shift linkage?
PK4058398 8548 2443
Tail shaft #s;
83-------------5
3608600
05111
TIA,
Dallas
Motor is a 318 from '81 - '85. Looks like a heavy duty 904 you have there.
Cheers. Gaz.
Thanks for the info.
Trans is in a friend's Dart behind a 360. He purchased the car with this set up and thinks it doesn't have the correct 360 converter in it. He was wondering what the original application was.
Dallas
I bought a 1970 Dart with a 340 and a 904 transmission. Dont know what year the trans is. Trans numbers are PK4202675X 7532 4012. Would appreciate any help I can get on this. Thanks in advance.
