Dakota_Don
- Joined
- Mar 19, 2008
- Messages
- 200
- Reaction score
- 1
HI, a buddy of mine got this 91 chevy 3.1..
it wont start, we checked the fuel system, and had 40 psi at the valve on the rail, it also has spark, but if we spray carb cleaner in the TB it will start and run, so he changes the psi reg.. and same problem
so it seems there is fuel getting to the rail but not into the injectors. So it seems the injectors arent getting a signal and The only way to check the inj, or the circuit is to remove the intake plenum. But before i do this I have a few questions..
does the crank sensor control the inj as well as the ignition?
can it be the computer?
im not getting any codes..
thanks
Don
Sorry if this is in the wrong section..if needed remove it or relocate it..
thanks
thanks
Don
thanks
