finally got a breather to install them on the 8.25 I'll be putting in my Duster (7.25 is kaput!). Swap was easy as pie, I was even able to "manipulate" the hard lines of the Cherokee to work on the 5th Ave rear.
had to take the grinder to the openings of the backing plate a little bit to fit over the ends of the axles. Cleaned and painted the calipers, new parking shoes and rotors. Now to get it under the car. Still trying to score some shock mounts/brackets/whatever so I can get it mounted. Then I get to figure out how to make the parking brake work...:munky2:
