Alex5280
74' Duster
Kinda slow at work today so I got to working on my Contour dual fan, soldering up the harness, ready to install and attach left side red/black wires to the relays, right side black wire is a ground:
IMG_3862 by Alexl5280, on Flickr
I think it was member goldduster318 that drew this up, thanks to him. This is how I wired it up. If you look carefully in the fan pic...You will see that I have it wired Wrong. I accidentally soldered in the #1 fan (on the left) ahead of the resistor hot (green/blue) lead. I will cut the connections out and fix this. The resistor must be the first in line joined to the main "hot" lead, before the fans as the diagram shows. Silly me.
Contour_Fan_Wiring_zpsfc112fe5 by Alexl5280, on Flickr
