64Dart270
Space Cadet
I am going to be installing a Transgo shift kit. I have been having issues starting the car already. Click-click, move the park lever, press in neutral etc... then starts. sometimes easy, other times a whole routine. After changing a faulty ignition switch (plastic terminal body separating from case), problem still persists. So, that leaves adjusting the cable. obviously, the neutral start switch is not getting fully depressed. So, I'm looking for non-textbook wisdom here. chilton has a whole routine about clockwise twist, line up hole, back off five holes, etc. Also, I've heard about using a test light on the Neutral switch. in this case, I will have the valve body out of the car, and back in again. I'm wondering if having the pan off gives me a better, less trial and error approach.
