[WANTED] A-904 parking cable end spring; 65 Valiant
jobrated_man
1965 Valiant and Dart
San Diego
Rating - 0%
0   0   0
Messed around with my 65 Valiant transmission and messed up the end spring on the parking cable end, the part that fits in the housing at aft end. I think the cable is ok but I removed the housing not knowing that cable could be removed otherwise. Just need the spring, if you have a parts tranny or parting one out. I think its the same in various models. see photo, end of spring is pulled out to become a straight wire.
Whoops, as it turns out, I was looking at the 62-65 Mopar site and noticed a picture of this spring on the end of the parking cable. it appears that it is normal to have a straightened end, with just a slight curl at the tip, so that the spring wraps around the parking yoke thingy, and holds it against the pin right there at the end of the cable. Guess i'm OK with it. Would like someone to chime in and confirm.
