I have this valve body I purchased from a knowledgeable and well known member here that I am not using.
I won't reveal who it is unless he agrees, but I assure you he knows his stuff.
Here is his description:
A&A model #22770-3hpr serial # 071120 forward manual VB in excellent condition. This valve body has low band apply. Will work in a 904 or 727. This valve body does not require the throttle pressure (kickdown) linkage to be installed.
I totally disassembled it and thoroughly cleaned everything, lubed the valves and re-assembled it so it's ready to bolt in. NOTE: I highly recommend installing a billet reverse servo if you don't already have one. This valve body runs at a much higher pressure than stock and can crack a stock rear servo.
Even though the date on it says it's 7 yrs. old I don't think it's had much use because the valves and bores had practically no wear.
This particular model # has been updated and here's a link to A&A's website with the newer valve body. http://www.aandatrans.com/Products/...Pattern-Valve-Body-(1966-80)__22770-3LPR.aspx
I would like 185.00 SHIPPED in the Cont. US, item will ship from 49259 zip code.
PayPal for payment.
Items will ship via USPS.
Please PM with interest.
PayPal for payment.
