A bad pass
67dartgtw9
Active Member
Hilltown,Pa
[ame="http://www.youtube.com/watch?v=wzx5sIM0Tog"]ABM track rental Dart save nov 2013 - YouTube[/ame]
My car getting out of the grove.
The only bad pass if you blow it up or smash it. That was just a learning pass. Nice car!
Low 9's @ 150...:-D.
I assume a cold track? Drag radials?
Regardless, that's gettin' it done. Stay safe my friend :salute:.
422 small block on 275/60 drag radials, and you can see my tag it runs around on the street on pump gas.
Damn that's a fast somebitch! More info on the combo!
So..... Nothing got broken and you had to lift momentarily part way down the track and you still ran low 9's on pump gas?
Sounds like a great pass to me.
took the scenic route to the stripe! Cool car! what intake you running?
I think we all agree, we need more info on your build please?!?
sweet.... for sure nice save an got back on the gas :prayer:
It's a r1a block 4.100 bore with a 4 in Calies crank. Diamond nitrous flat top pistons hard anodized. Scat rods 6.300 2 in pin with upgraded bolts. Custom bullet solid roller about 780 lift and 270 duration. Brett Miller cnc w9 heads 2.18/1.60 ti valves flow 397 at 800 with T&D rockers. Has 727 full roller trans with alum drums. 8 3/4 mopar 4.30 gear rear! Raced once a month at 10.0 indexes. Goes 9.51@141 on motor and has been 8.93@151 on a 175 shot. Just use in gone bar on crossbar plate trying to get the second kit turned on, not successful yet. I run pump gas on motor, driving it on the street and racing 10.0 index. When I run nitrous I put race fuel in it to be safe, I am sure I could get it to run on pump gas too.
[ame="http://www.youtube.com/watch?v=FlzA8qVg8S8"]pt 11 **ELIMINATIONS** Cecil county nostalgic drags june 8,2013 - YouTube[/ame]
Go to 6:30 in video. A cleaner pass. This is the 772 intake and at lot of power pulled out at the hit. This pass was a 1.41 60 ft and the bad pass was a 1.32. Need to get it all together and get the second kit on. Want to run 8.50 index with a street car on small tires. All the cars in that class are big tire race cars, think it would be cool to play with them.
