cody.bourgeois
The Suspence IS KILLING ME>>>:burnout:
Are different sway bar sizes/rates available?
Hope you like....
And a Thank You to....
Ross....help develope the Super Slammer
Shawn..pushed for the box tube crossmember (now standard)
Andrew...turned on the sway bar light bulb
Randy...his trust and patience
and my buddy HemiMark...who helped thru the years build and experiment on the early (1996) K-frame packages.
Hope you like....
I cant wait to get it in place
Andrew
Denny I think it will, if not I will modify!
Andrew
Looking good Denny............
Hey, I know of this easy inner fender mod that would take care of the rub problem......small taters. But seriously I wouldn't change it, the car sits and looks awesome. The wheel wells look stuffed with rubber, very mean !
the rear dropped a little when i put a full tank of fuel in 'er....the front is as low as I can go and still get a couple of inches of compression without rubbing on the tops of the inner fender.......think it sits OK or still too high?
really...I don't care what you guys think....I'm just trying to add to my "replies" stats.
I'm saving up to win a car
:sign3:Old Man Mopar ............ Leave it alone!
Finally gettin it to haul a$$....I think I'm 98% there
