j.mcconnell
Mopar 8-3/4" rearend for an A-body. 1970-1976 Dart, Duster, Valiant, Barracuda, Scamp, etc.
Factory width axle housing
3.91 geared 489 Sure-Grip case with 1350 pinion yoke
30 spline axles large 5x4.5" bolt pattern with green bearings from Dr. Diff (no sticker Yukon axles I believe)
Factory drum brakes, new pads, new stainless hard lines, new flex line, e-brake cables
New spring perches set for 3" inboard springs
The housing and center section are original and everything else has 150 miles since being purchased new. Bolt-in and drive if your springs are in-boarded. If not, weld on new perches and go.
$1200. Located in Apex/Raleigh, NC. No shipping at this time.
