[SOLD] A-Body 8 3/4 Rear Complete
FastMopar71
Lehigh Valley, PA
Rating - 0%
0   0   0
For sale is an A-body 8 3/4 rear. 2.76 open gears, 742 case, small yoke
. Rear is complete with housing, gears, stock SBP axles, backing plates, brakes, drums and emergency brake cables. Came out of a 70 340 Duster. Located in Northeast PA. Local pick-up only, will not ship. $850
Can you message me where you are located and do you know if it would work in a 74 dart swinger?
Is this still available? Do you have measurements flange to flange and mount to mount? Thanks
Yes it still available. I do not know the measurements off hand. It is a stock A-body rear out of a 70 Duster. I'm sure you can google it and find out the measurements. What are you looking to put it in?
1965 Dart - in the philly area
If it's a stock A body rear, it will fit your car! You may have to use a C body rubber brake hose as the distribution block was moved down the tube some in 1970, and your current hose may be too short!
