will 28" axles fit in a a-body rear housing or will they need to be cut down, and does anyone know spline length on the stock axles if I need to cut the ones I found down to stock a-body length
8 3/4" axle shaft lengths measured from the tip of the splined end
to the outside of the flange:A BODY
'66-'72= 27 11/16"
'66-'72= 27 11/16"
