A Body Floor shifter linkage pictures or diagram
Scatpack1
TN
IF this is not the right Forum, p[lease advise and I will re post it in the right one. Working on a 71 Demon with a floor shifter. Owner wants to install the console and shifter linkage. Does anyone have any pictures of the console brackets and the linkage pieces installed? I have most of the pieces, but will have to fabricate a couple of the floor braces for the console and want to make sure I do not miss any of the linkage or springs on the linkage.
thanks in advance. I usually lurk around in the racing forum, but thought you guys may know the stock pieces answer.
Assuming automatic?
There are 2 brackets welded to the floor for mounting the console. 2 screws on the sides up front and 2 more screws accessed through the console opening into the orher bracket. I think AMD reproduces them.
The shifter linkage is as shown in post #2. There is a wire loom for the reverse switch that is on the shifter bracket.
Factory Service Manual has more info.
Here are what the brackets look like. I think AMD makes aftermarket ones.
