[SOLD] A body rear upper shock studs
moparmat2000
Grand Tetons
A body rear upper shock studs with washers and nuts as you see shown. Glass bead blasted. Threads are real nice, no pitting. Coated with light machine oil after pic was tsken, and ziplock bagged to prevent flash rust. Asking $35 plus the ride. Located in west Texas. I accept PayPal.
Hey Matt, I'm installing rear shocks in the 69 cuda in next couple days. Have you got pics of required hardware(bushings/washers) for the upper stud? I have the cupped washers for bottom, but nothing for the top.
Thanks, and bump for ya.
Hi Steve, it's the same cupped washers used on the upper studs as the lower ones. Big hole cupped washer on the shank, small hole cupped washer behind the nut. Everything I have seen shock stud wise uses stove nuts or some sort of mechanical locking nut, but not split lock washers
