I am charging my a/c system and have a question. When I set the a/c to max a/c the compressor clutch is locked and the compressor is spinning but when I put it to normal a/c the clutch does not lock up. Is this normal.
'74 was the first year the A-bodies got an EPR valve and the compressor is powered full time when the mode selector is in "MAX", "A/C", or "DEF" positions (assuming the low- and/or high-pressure cutoffs are closed, if equipped). If your compressor clutch isn't getting power with the selector in "A/C", you have probably got a faulty selector.
