Dodgenut64
OK, im gonna try out a 93-97 jeep grand cherokee radiator for my 64 with the 5.7. Its got the right hook ups and will fit (with a few mods) into my car. Heres the question i have, when getting an a/c condensor, do i use one big enough to cover the radiator or do i order one big enough to help the 66 dart size evaporator? Id think a bigger one then the 66 size condensor would be a good thing, but then i wondered if there was such a thing as too large of a condesor. My thing is, if a 66 size condensor will do, and it leaves a little more breathing room for the radiator then shouldnt i go with it? I havent been able to find the dimensions for a 66 a/c condensor, so it might be close to the same size a grand cherokees. Also, are all the replacement A/C condensors rated for the new A/C coolant? Does any of this condensor size stuff matter or should i go with a condensor that fits my needs as far as the location of the hook ups? Thanks
