SlimPikins
Pikins, Slim Pikins.
I have searched quite a bit without finding the answer to a lot of my questions. I researched my fender tag and most of it makes sense. A few questions I have is:
My motor is listed twice.
Once it says: G4G: 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL
And once: E44: 318 cid 2 barrel V8 230hp
Which horsepower version do I have in a 74 Dart?
Also the tranny says:
D34: Light Duty Automatic Transmission
That is from MyMopar dot com, From StockMopar dot com it says:
D34: TorqueFlite Automatic Transmission
Can I safely assume that it's a 727?
There is no listing for the rearend. I am curious how I go about determining the difference between a 7.25 and 8.25 housing. I took (crappy) pictures of mine I can post if that helps.
Thanks in advance for any help the members here can give me!
Slim.
Here is the full results from MyMopar:
LH23:
Dodge Dart,Demon
High
2 Door Hardtop
1974
St. Louis, MO, USA
232387: Sequence number
HL4: Parchment Exterior Color
E2Y3: Trim - Unknown, Vinyl Bench Seat, Gold
000: Full Door Panels
418: Build Date: April 18
943060: Order number
VIY: Unknown Top Color
U: USA Specifications
B41: Front Disc Brakes w/Standard 10in RR Drum
G52: Unknown
H51: Air Conditioning with Heater
J25: 3 Speed Wipers
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M25: Wide sill moldings
M26: Wheel Lip Moldings
M38: Decklid Finish Panel Moldings
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
Y16: Sales Bank
26: 26in Radiator
END: End of Sales Codes
Slim.
LH23:
Dodge Dart,Demon
High
2 Door Hardtop
1974
St. Louis, MO, USA
G52: Unknown
J25: 3 Speed Wipers
Y16: Sales Bank
26: 26in Radiator
