TrailBeast
AKA Mopars4us on Youtube
Sometimes I will wait to get something for months if I don't see exactly what I want, and this was the case when I decided to get some fender covers.
The problem was that I kind of wanted the Edelbrock Racing fender covers but they don't have pleats or anything made into them and on my Dart they either had to be hanging so far into the engine compartment they were in the way or they would just slide off onto the ground.
PLUS, even if you did let them sit clear in on the inner fender so they would stay in place there was really nothing flat to lay tools down on then without them rolling off into the engine compartment or on the ground.
My solution was to use a section of 1/2 x 1/2 square tubing and the black 3M weatherstrip adhesive to roll the tubing into the end of the covers.
I placed the tubing along the edge of the cover and ran a bead of the 3M along side it, then roll the tube into the adhesive and back out again to let the adhesive dry a bit, and then roll it back onto the adhesive.
I continued this process until the cover material was adhered to the square tubing on all sides.
Now when the covers go on the fender the foam wrapped tubing sits just inside the fender lip holding the cover in place as well as giving a flat area to set tools down.
With the cover being wrapped all the way around the tubing everything touching the fender/paint is padded, AND it holds in place even in the wind.
When I am done I just roll them up and put them in the trunk, and they stay nice and neat with no creases in them.
