DaveBonds
Garage Trash
Hello, FABO.
I'm after a few hard parts for my transmission project.
Local swap meet today didn't turn much out for me, so I'd like to give my unused money to those here looking to move unused parts before going other places.
I'm working on a 23 spline input, 4.8" index bearing retainer short 30 spline output main shaft trans.
Condition of each part is not a huge factor, so long as it isn't beyond use. I can deal with rust.
-Bellhousing dust shield, dents and rust aren't a huge deal
-Short tailshaft housing for 30 spline yoke main shaft (non-companion)
- 30 spline yoke for driveshaft 727 uses the same size
-Straight cut reverse gear for main shaft
-Countershaft and Sleeve
-1964 -1970 1/2 Shift lever & fork
-1964 -1970 3/4 Shift lever & fork (any metal on the forks is fine)
-1970 & up 1/2 Synchronizer sleeve w/3/8" key size
-3/4 Synchronizer sleeve and drum that are matched
-Front bearing retainer with 4.807" diameter index and 4.16" bolt circle
(not to be confused with bolt pattern diameter, as the pattern is not a perfect cross and measures differently.)
Let me know what you've got!
Thanks!
Dave
Thanks!
Dave
