A few more pics
Michael Siple
Wilmington, De.
Anyone see something needing attention ? install timing set 6-12 dot to dot, degreed cam & had to retard crank gear to get centerline ( 3 degrees), #1 at top, dot on cam gear & "new zero dot" on crank gear line up dot to dot, mock up timing cover and slip damper on enough to catch key and they look like they will zero.
You have moved the cam. The crank didn't move. TDC of #1 is still in the same place. You just moved where the cam is in relation to that. It's ok.
