71dusterdan
Hey everyone, anybody have access to reference materials that can identify these trans parts?
1 aluminum bellhousing the only numbers it had were on the trans mounting side... 3 43859 05305-1 77
2 trans number 1 cast iron case, aluminum tailshaft, bearing retainer just shy of 5 inches in dia. right side... 10/5/76 013386 c 99129 h numbers on the retainer c97728 pad stamped numbers 2BI27926 pp883 3605 0036
3 trans number 2 all aluminum pad stamped numbers 7B369331 833 5751, shifter side c13303G 4-5-77 retainer numbers 013157 11/16/76 c13386 retainer is same size as above, just under 5"
Hopefully somebody out there can tell me what I have here. it appears they are both mid 70's, if I am guessing those are actually dates. Makes them f body or a body.....if they are either. short shafts, shifter to rear of shaft. Thanks a million!
