I finally got me a big air compressor my old 25-year-old Craftsman filing pooped on me
That looks like a good one. IRI finally got me a big air compressor my old 25-year-old Craftsman filing pooped on me
Got any pics of how you put a muffler on it ?I have the same one. I've had it since 2013. I put a muffler on it, as well as left it on the pallet. It helps with the noise. Make sure to put a manual or auto drain on it.
It's been a good compressor. I painted a full car with it.
Did that muffler quite it down any ? and where can I find one if so !Here we go. I had to go 90* because of the low ceilings. I also added a trans cooker right off the pump to cool the air going into the tank as well as added a out 45 feet of black iron pipe with drip legs and ball valves.
I get no moisture by the time it's at the second to last drip leg.
Use the old tank, and double tank it, you will never run out of air.I finally got me a big air compressor my old 25-year-old Craftsman filing pooped on me
You can barely see the power supply in the bottom pic. The power supply converts 120V AC to 12V DC, which is what the fan runs on. I have it wired in the pressure switch to supply 120V to a regular house type plug that I mounted up under the frame of the compressor. I made the bracket to mount the cooler and the fan and painted it with a spray bomb from Home Depot. The paint matched the Quincy Blue just about perfect. I saw this mod on a You Tube video that a guy who has put up. He listed all of the stuff needed in his description. His video makes you want to it's so drawn out, but his idea and execution were great. He ran the AC wires from the power supply straight to the pressure switch. I changed that part and ran a piece of 14 gauge Romex from the pressure switch up to a standard outlet so I didn't have to get back in the pressure switch if the power supply for the fan ever took a dump. If it does, all I gotta do is unplug it, plug a new one in and test the 12 side to make the fan rotate correctly, since wiring it backwards will make it spin wrong. I have it blowing thru the cooler instead of sucking air thru it.How did you get the 12v fan to kick on when the compressor does? 120v vs 12v?
