- Joined
- Dec 31, 2005
- Messages
- 7,218
- Reaction score
- 4,350
Means nothing to me. Are you sure its a 1972 TQ?A/F is 12.8
Positive.Means nothing to me. Are you sure its a 1972 TQ?
What's the number on the top?Positive.
If you look at the top near the bowl vents there will be a numberIt's a 6139.
6-2080If you look at the top near the bowl vents there will be a number
That sounds like the right top. Have you checked the IFR to make sure it isn't blocked or restricted in some way.6-2080
Idle Feed Restriction. If you pull the top off and turn it upside down you'll see where the the fuel travels up at an angle towards the booster outlet. Inside there is a little pressed in tube that should measure 31 thou from memory.Well, I cleaned the hell out of it and blew out all of the passages and installed a new kit and adjusted it to the OE specs. It actually looked really good when I first received it. It was a late 70's take off from a Barracuda and then shelved. No evidence of dried fuel or varnish. LOL...It was delivered in a '70's Holley box so I can imagine the story.
BTW....Pardon my ignorance, but what does IFR stand for?
