66Dvert
Working on my custom car parts again!
I just got back from going to michigan (friend of the family's wife passed of him suddenly) But while I was there I scored a 96 sebring brown cloth set of seats. front and rear, they're sorta dirty but no rips and the driver side is power! And I got em for a hundred bucks. wooooohooo!!!!
I just stuffed them in the rear to see if thay'd fit and it'll be close
the backs I'll have to shorten up a little on the sides to clear the sidepanels and the bottom might need it but it's really close
I need to go to a junkyard around here and get the metal support for the top seatback/seatbelt mounting bracket but it looks do-able
back sort of squeezed in there. I'll have to build a raised pan to mount the seat in the correct position((and not bend over the Hump
YehHAWWWWW front power seat(still have to test it)
another pic of the rear seat , yup I'll have to shorten it up about and inch on a side, easy it's all foam there :cheers:
a back view showing where it mounts and the piece I'll need to scavenge from a donor sebring for the mounting and seat belt mounts
A shot of how it's going to go into the car, it'll be about 2 inches lower on the back seat but it should be ok
another view showing how far I'll have to build up the mounting pan to get the correct height. of course that's after I level everything out and shorten it to whatever size I need to make it fit
so maybe they'll be comfortable on a long drive
well I can only hope so
