A Valiant BJ / Powerdyne BD-11
Brad426
Ottawa, Ontario Canada
Now I'm getting to the fun stuff. I've had enough scrapping and painting for now.....I started to install the BD-11 and had to do a bit of body work for clearance. So far so good. I'm trying to figue out how to feed filtered air to the blower. The K&N is their to keep the bugs out for now but, I may have to stick with this set up. The filter holder with the kit is too big to mount anyplace between the blower and firewall. So it looks like a ton of ducting is needed. My other option is to tap into the pax side snorkel on the hood...again it's getting complicated. Stand-by. :coffee2:
I added a fine brass screen between the compressor discharge & intake. Just incase of FOD (forgien object damage). If the compressor internaly digest something or the compressor blade glue fails. This migh stope FOD from going into the engine.
very cool Brad426....you may have inspired me to fit up my BD11A to my 360.
what improvements have you made to the BD11 if any. i have fitted the 928 bearings, belt, impeller shaft, and had the drive cog lightened. had considered a Vortech but on reflection the powerdyne now owes me $$$ so may as well see what it will go like.
love the green.
cheers
love the green.
cheers
STOP! DO NOT RUN YOUR BD11 WITH 928 MOTORSPORTS parts!
You will distroy your engine & blower. Please do not use anything from 928. I will be happy to tell you why with photos, documents & the works. I have the evidance. Do you recall if the 928 bearing were stamped KBC. OMG! Buddy Karl is bad news.
yes the bearings were KBC. i was very surprised to have recieved $3 bearings packed with some magical grease. not the product i thought. the kevlar belt did not have any markings on it. i have contacted carl with no response to date. glad i never got the billet impeller from him then.
OK so who and where do i get the right bearings for my BD11A. these things should be fine with the right parts?
cheers
You will need to get that air filter into cooler air for sure! I read that you were thinking of leaving it where it was?
I agree but, for now I have this......:cheers:
More info on bearings
POWERDYNE BD11 IMPELLER SHAFT BEARINGS
Powerdyne Factory Installed (Factory New)
Manufacturer: SKF
P/N: 6202-2RSTNH/HC5C3WT (Highest quality)
6 = deep groove ball bearing
2 = width / height series
02 = bore size of 15mm
2RS(H) = two contact seals
TNH = Injection molded cage of glass fiber reinforced polyetheretherketone (PEEK), rolling element centered
HC5 = ceramic rolling elements
C3 = greater than normal clearance
WT = special grease fill for temperature range -40C to 160C
WT Grease fill for low as well as high temperatures (e.g. –40 to +160 °C). WT or a two-figure number following WT identifies the actual grease. An additional letter or letter/ figure combination as mentioned under “HT” identifies filling degrees other than standard.
Examples: WT or WTF1
Replacement Bearing SKF from KAMAN AEROSPACE (Acceptable Replacement)
Manufacturer: SKF
P/N: 6202-2RSH/C3GJN
GJN = grease type
GJN Grease with a polyurea thickener of consistency 2 to the NLGI Scale for a temperature range –30 to +150 °C (normal fill grade)
928 Motorssports HP Bearing (Non-Special Application)
Korea Bearing Company (KBC)(now owned by FAG)
P/N: 6202Z
Z= single or double shield
The KBC 6202Z cross references to a SKF Explorer bearing 6202-2Z (the Z or 2Z means double metal shields)
Limiting RPM is 22,000 rpm for a quality SKF bearing only.
Limiting Temperature range see diagram 1. At an average engine compartment temperature of 210 degree F
a SKF 6202-2Z bearing has a max. rpm of about 5,000 rpm.
Same thoughts. No Intercooler also. I really think the OP is going to need at least some Meth Injection to keep the IAT's cool enough and stay away from detonation. Boost does not get along with Hot IAT's, Detonation will follow.
Your right on that front. I have a water/alco. injection kit to install later. I want to try it this way first and see what it does. The EFI computer will record each run and show me any A/F, temp. spikes and EGT. I can fine tune after that or modify.
You should really think about putting the Meth kit on now. Detonation has "NO REMORSE" it will destroy your engine faster than your computer can react. I would hate to see you ruin your engine before you get a chance to use it. You have alot of $$ into your build.
I also see a carb, not EFI, am I missing something??
Here is a good read for you.....
http://www.alcoholinjectionsystems.com/
I
That's some REALLY GOOD advice, I think. My system (Vortech V-1, S-trim, NO intercooler,) but with a Snowperformance Boost Cooler, is set to come on a 3-psi and sprays all the way to my max of 10, and I have had ZERO detonation problems running it that way on AV gas, both at the drag strip and, at the chassis dyno. I run pure meth in it, no water.
I can't see any good reason to tempt fate, and run it with NO intercooler and NO alky injection, only to add it later (the meth.) It's just too big a chance to take, with possibly disasterous ccircumstances, especially, since you're going to add it later, anyway.
The advantages of having it early-on, would seem to far outweigh any perceived disadvantages, to me.
Just my 2-cents...
"Detonation has no remorse..." I LOVE IT!!!:blob:
OK I'll hook it up. I could use your advice. If you look close that is not a carb. It is a Projection III EFI...
I have the W/A pump & nozzel but, have no clue as how to rig it up. Should the spray nozzel be on the intake side of the BD11 (compressor side) or output side? I've seen what water does to turbine compressor blades.......Thanks
I have heard testimonials both ways. I chose a location dowdstream of the compressor, but I didn't have any solid evidence that that was the "right" way to do it. It seems to do the job...
I ddin't want to put the compressor impeller in any kind of jeopardy, unnecessarily.
He's a pic...:wack:
Thanks Bill. Nice set up. I have to lean the "after" the blower school of thought as well. Water is as hard as a rock at the compressor speeds. One less thing to come loose and eat the compressor. What do you use to trigger the pump?
Wow, first I seen of that product. Pretty cool! Gunna do some research on it.
As far as the nozzles you can put them before or after or both. On your system I would probably do both.
Here is a diagram for you... There is also information on the site about spraying on both sides of a centrifugal super charger.
http://www.alcoholinjectionsystems....-My-Water-Injection-Nozzles/article_info.html
The Snowperformance Boost Cooler kit include a "Hobbs" switch (I guess that's what you'd call it,) that is connected to intake manifold vacuum/boost with a small-diameter hose to monitor conditions. It has a small female Allen hex that can be used to adjust the onset of spray; your choice. I use 3 psi on my low-boost application. YMMV...
Hope this helps... O:)
With the PJIII you need to do one other thing if you plan to use methanol injection. Activate the E85 setting (brown wire) via the Hobbs switch you use for the methanol.
The problem is you are adding fuel (methanol) and the PJ will see that & pull fuel out of the injector cycles.
What you want is boost ENRICHMENT. By switching to the E85 settings you get the fuel curve offset under boost.
B.
B.
That would seem to me, to be a REALLY good idea!!! Never thought of that...
B.
When referring to a Meth Injection Kit I was referring to the Kit itself. You don't need to spray 100% Meth. Alot of guys just spray 100% Water or even a 50/50 Mix of Meth and Water. You will not get the Fuel explosion that most think you would. When injecting the "Spray" it is broken down in to a Misty Steam which cools off the intake charge & Cylinder Temps. This is what you are after, not using it for another Fuel Source.
I believe what you're saying here is true, but at the same time, I'm wondering if, due to the increased volatility of methanol vs. water, if the greater evaporative nature of the alcohol might not give additional cooling, when atomized. I have NO information to support this, I'm just asking. It seemed plausible to me...
What do you think????
Not running an intercooler has me wanting all the charge cooling I can get...
B.
THANK YOU! I never though of that. Other than hooking up the brown wire to be hot when the boost switch is activated a 3 psi. Do I need to flip and swiched or adjustments in the Stage III programing. BTW. The wiring doagram in the PJIII instructions says the brown wire is for future use.......Did we time warp?
:prayer:
