[WANTED] A833 /904 7290 Slip Yoke
I thought the 904 yoke was much smaller than the 4 speed yoke?
Of Course, I am Old and memory is not great!
The 904 is small-7260 and the 66 A Body A833 uses the small 904 slip yoke. All other A833's and the 727's use a larger slip yoke, can be 7260 or 7290. Mopar Performance used to offer a 7290 slip yoke for the 904, and I think they were used on some Dodge Dakota's
So did I!
I need this for my 1967 26 spline 833 4 speed.
The 904/833 26 spline 7290 yokes are around. Just hard to find.
I stole this 4 speed explanation from another post here.
I have the part number out in the garage. There might be one floating around somewhere. I might have an extra one. I'll look.
I believe you can purchase one from A & A transmissions brand new. At least
saw them last time I was on their website. Not sure the cost.
I thought the 67 A body was the large one also, but since they used the small spline A833 behind the 1966 273, they possibly could have used them behind the 67 273 also. I'm not sure.
Is not the 904 yoke diameter smaller than 1967 up 4 spd yoke?
Like the title says, I am in need of a A833 /904 7290 (Large) U Joint Slip Yoke.
I sold a 7290 904 to an overseas member a while ago and might have one more. I will look around today. Here is a picture for reference, the 7290 below the 7260 has the casting number right on the yoke and is big and very visible.
Yes, '66 and '67 still used the 25/26 spline slip yoke unless you had a 383 engine. Those came with the 29/30 spline yoke.
