A833 cast numbers
kempi
Member
Berlin, Germany
Hi,
maybe anyone could help me out on this one.
a guy offered me a 833 trans and said it was for an a-body. He gave me the cast number on the trans-housing: C937372 and of the tailshaft-housing: C96706K.
I couldn´t find any of these numbers neither in the chrysler parts interchange manual nor at mymopar.com.
Hope someone can tell me what kinda trans it is and if it will fit a 68 dart.
Thanks
You will find on the right side of the tranny case a machining pad with all the info you need,if the info is their,post it,if none is there,then it is a replacement unit.
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
If you go to this site you can help ID your tranny by parts that are on it.If you post the tranny cating numbers on the pad I will decode them for you.Mrmoaprtech
