dodgedifferent2
I have an a833 four speed for A bodies
Aluminum main case
Ball and detent cast side cover
New bearings gaskets and seals
Cast tailhousing.
Does have a brand new big block bearing retainer from passon performance.
First is 2.66 and fourth is 1:1
NOT AN OVERDRIVE!
You will need to modify the small block bell housing to fit
The aluminum main case shaves at least 20 lbs off the weight.
Never bolted the transmission into anything. Just finished rebuilding.
Main case has been bushed with steel inserts on the cluster shaft to take away the known aluminum wear issue.
$1100 plus shipping (prefer local pickup)
Aluminum main case
Cast tailhousing.
NOT AN OVERDRIVE!
