db's demon
When you go to measure driveshaft length, do you push the yoke in till it touchs the seal or do you compress the seal till the yoke bottoms out then pull it out 1"?? This is the seal that is about 2" long. Thanks D.B.
If this is reasonably inmodified car, what you stated is about right.When you go to measure driveshaft length, do you push the yoke in till it touchs the seal or do you compress the seal till the yoke bottoms out then pull it out 1"?? This is the seal that is about 2" long. Thanks D.B.
