A833 syncro
grjammer
PA
I am planning on changing the syncro hubs and sliders in my A833 OD unit and wondering if the parts are the same as for the 1:1 A833.
I know the main shaft is different for the smaller "3rd gear",(OD)...but don't know if the 1-2 and 3-4 syncro assemblies will interchange between the two types.
I have to wait til tomorrow to get the bearing off the shaft, and I will call Passon or brewers, just looking for an answer to check new parts availability.
:burnout:
This is what was causing trans to be stuck in 2nd. brass has tip broken away allowing the syncro key to move farther in the travel, overcentering and jamming the syncro slider. Probably a broken spring was the beginning of the end. I will replace springs keys and brass on both sides and see if this fixes the issue.
