74Dusted
Stock Piler of 340's
I know it sounds bizarre, but I'm thinking of installing an A833-OD in my 1948 Dodge Truck, and in the nature of a "Stock" Appearance what better way to match the era than a Twin or Triple Stick Shifter setup. One Shifter for 1st/2nd, One for Direct Drive/Overdrive (4th gear and 3rd/OD) and one for Reverse. (Or a 3-Speed Shifter that shifts 1/2 and Reverse, with a separate shifter for Direct/OD)
Mostly it'd be pretty damn simple, 3 linkage rods, a pivot for the shift handles to anchor to, etc. But I'd have to devise a way to lock out each shifter so that 1st/2nd, Direct/OD, and Reverse couldn't be accidentally engaged in pairs at the same time.
Any ideas on such a setup?
The original plan was to Install a "Brownie Box" (Auxiliary Transmission) in the truck, but with the 4WD Conversion and Divorced NP205 Transfer Case I don't have enough Wheelbase to fit a Brownie Box and Transfer Case under the truck. With just the current 4-Speed and a Transfer Case, the Rear Driveshaft is going to be about 29" Long.
So instead, I'm going to go with an A833-OD instead with a Divorced 205.
