A833OD Reverse Gear interchange?
DionR
Spokane, WA
I've been having problems with my A833OD sticking in 4th so it is now out and on the bench. During inspection, the points on the reverse gears appear to be fairly rough so I am thinking about swapping them with parts from another OD trans I have.
Per Passon's book, there are different reverse idler gears and sure enough mine has no markings but the parts idler does. Best I can tell, the 1-2 slider is the same and the reverse gear teeth on the cluster are all suppose to be the same.
The trans out of the car is an '75 iron box and has the 18t 4th gear setup while the parts trans is an aluminum case out of a truck (I think) and has the 20t 4th gear setup. So I know stuff like the cluster and input won't swap, but the reverse idler and slider are unclear to me.
So can I swap the slider and idler from the parts trans? Or am I going to run into problems if I do so?
Reverse has been rough, but it's not unbearable, I would just be all the more careful if I left it alone. So it isn't an absolute that I do this.
It's probably NOT the Reverse Idler gear sticking, nor the Slider, but instead
is the internal shifter.
Try shifting it without the cover.
I bet it shifts just fine. If not, remove the detent system off the backend and try again. It should flick in an out like magic.
Here's the deal, There are two internal shift levers available for those, the difference being the clearance between the the cover lever and the trans lever. This is to prevent accidental reverse engagement together with First which could be catastrophic.
If it does shift fine without the cover, then I can guarantee that you have interference.
The usual cure is to mount the cover with only the one bolt that has the long shank on it, in the appropriate hole near the Reverse switch, and any other short shank bolt. Then Push up on the cover while tightening that longer shank bolt, followed by the other, still pushing up.
This will create the maximum amount of lever clearance.
If it is still not enough, you have two options;
1) go get the other internal lever. They have identifying marks on them, but I forget where, and what the marks are. IIRC one of them got an "X".
2) machine yours. Go look at the top of the trans lever. If it has been interfering, the witness marks will be on it .
The cover levers are all the same. But I doubt it maters which one you shave.
BTW
You are right, None of those gears are interchangeable, the teeth are not cut on the same angles, and the tooth counts are different.
The 18 tooth od gear is too fragile for use with V8s. Even the 20tooth will blow up if you forget to half-decent match the rpm to the roadspeed.
I have blown up one of each with little more than flywheel-effect. But the 20tooth did last longer.
If you look at the sliders you will see that they are coded by having grooves on the faces furthest from the cluster. You'll see the grooves right away when you lift the cover off. As long as the grooves are of the same number, say both transmissions have two-groove sliders, then they will interchange. To tell the truth, in my experience, as long as the strut system is the same, any slider will interchange with any other.
Watch out for the 6-cylinder versions in the which the slider can only be installed in one way, to engage the struts. I wonder how much money Chrysler saved with that bone-head move.
Ok so
Give it a try.
The trans is apart already and the sticking issue identified. The middle of the dog spring on the OD side had popped out from under the dog and so the dog was rocking up and not allowing the slider to move over it and out of 4th. Based on wear marks, I would guess the spring was even holing the dog out of position and not allowing it to drop, further exaggerating the issue. That was all pretty clear when we popped the side cover off.
The question was only in regards to the reverse gear stuff and if it interchanged.
BTW
The interesting thing (to me) is that according to Passon's book, I should have had the 20t gearset. The 18t gearset is a '77+ deal, according to his chart. Thinking back on the history of this box, pretty sure this is the one I originally put in the car and I think it came out of an F-Body when I first put the car back on the road. The casting date on the side cover is '75 and the build date is June 4, 1975, so maybe it is a '76 Volare box? But even if it was an early '76 MY box, I would have thought it would have the 20t gearset.
In regards to strength, you and I have talked about it multiple times. This box has lived behind my mild 360 for many years so far and hasn't broken. So I see no reason to change things beyond the sticking issue and maybe improving reverse engagement.
I would be interested to see any pictures you have of the 6 cylinder version. Having trouble visualizing what that would look like.
If the struts popped out once, they will do it again until you replace the brass. The brass is going down too far on the cones.
The one that popped out is not the one that needs replacing, rather, the adjacent one.
When reusing old brass;
Put your highest sitting brass on the input gear as the input gear, from the factory sits really far forward.
I put the next best brass on Second, for two reasons; 1) cuz it wears out the earliest, due to it seeing the most action.. and 2) cuz the stinking 1-2 split is 54% so that brass is always having a hard time.
I put the most worn brass on overdrive, cuz it sees the least action.
For First gear, I choose whichever brass works best in the Downshift direction.
as to forks
If the forks have been brazed to replace lost material, make sure they are not too fat.
If the forks are bent, throw them away. They will overshift one way/undershift the other.
Other
I use the later style cover which cannot overshift.
If you use the early style cover, make sure the inter-lock pin is good and long, to prevent overshift,
Oh crap, I misread your original post. I missed that you had TWO problems, Sorry about that
Good luck
Brass is almost new, it was replaced maybe 8K miles ago? And they sit pretty high and grab well.
The spring on the other hand looks pretty deformed when compared to one out of the parts trans. I will re-assemble the slider with the bad spring and see what I see though.
as to forks
Other
Good luck
Thanks.
