joshua dewitt
hey putting it out there... I removed my 1978' ish a904 hydraulic lock up transmission... opened up to find the problem, a ha... burnt forward clutched and steels. now.. going to make it a non-lock up model for a back up if and when I blow the a904 I built up for the current dart.... other than the input shaft,,,, and converter, and valve body... what else would I need, it has a 5 clutch setup already. all looks good other that the burnt clutches and steels in that section. can I used the same front pump and stator assy? they are in rear good shape....
