So as indicated I'm putting an A500 (RH42) into my 70 Dart which originally had a A904. I have a set of new lines for a 70 Dart with a 727 and it seems that the lines are bent in a way that I can use them all the way up to the K-frame. At that point I was going to transition to rubber lines to a cooler mounted behind the grille.
The cooler is made with 2 inlet/outlet nipples (see picture) and I plan to mount the cooler so that one nipple is at the top and one at the bottom. Given that one of these is a pressure line out of the trans and the other returns fluid, I presume that I should be pumping into the top nipple and running the return out of the bottom. Is that correct?
Next question is which of the fitting holes in the trans is which - Is the fitting toward the back the 'pump fluid out line' (that's a technical term) or the one toward the front of the trans???
Thanks for your help!
