[WANTED] A904 Torque Shaft Bracket
TRDuster
valdosta, GA
Rating - 0%
0   0   0
Looking for an a904 Torque Shaft Bracket on a 1972 Plymouth Duster with a column shift. Apparently it looks like the longer of the 2 pictured.
This is the only picture I can find that shows the 904 and 727 side by side. Too bad they did not include a ruler in the picture like you did. I think you have the 727 version. Are they both the same size? How much for both?
Here is a 727 (shift torque shaft mount) in a small block D100 '76 truck.
Auto on the column.
For comparison...
Torque shaft bracket that bolts to frame: Chrysler part number 2467932.
Same number used on 1966 - 1976 Abodies.with 904 or 727 transmissions.
Check out these pictures on eBay.
