I'll just leave this "rat cheer".
Years ago I worked for a company that built a new shop. The air compressor was installed over a small "room" double entry to stop cold air entry in the winter. The air outlet from the tank had a loop up to stop any moisture getting into the shop air lines. After a while I noticed the compressor would cut in almost immediately. So I mentioned that I thought the compressor needed to be drained. Response was the loop stopped the water, to which I replied "where does the water go?"and drain the tank on a regular basis. Hmm, I wonder if they remember to do that at work?
In industry to test vessels and pipelines, they fill with water or water/methanol in freezing conditions. This is then pumped up to a much higher pressure than normal operating pressure. This is usually 5000 to 10000PSI. With a liquid fill, if a failure happens the energy is relieved quickly which vastly reduces the potential for injury. When a gas such as air is pressurized and a containment failure happens, that gas expands rapidly. Severe injury can happen.Thanks for posting, Del. It blows my mind that so many people are doubtful that compressors can ever explode like this. I've gone 'round and 'round with the guys at work and they always say it'll never happen and that if a tank ever deteriorates to that point, that it'll start with pinhole leaks and gradually fail. I say that's horse puckey. If you're lucky, that's what will happen, but you can't depend on it. And this video proves it.
ALWAYS drain your tank at the end of the day and leave it open to let any condensation that didn't get blown out evaporate. Keep that tank dry and rust-free. There's even some folks who install coolers between the compressor and tank to minimize condensation in the tank, which I plan to do.
Occasionally this comes up and at least 3 people are always, "well I've never seen this how often does this happen?"
Answer? I don't know but I'd guess "it only takes once." A friend of mine recently gave me a typical cheap china import that had rusted through the tank. It had NOT exploded, but had rusted through and leaked and he caught it and realized what was going on
You could drain the pressure and remove the discharge to the tank line and the fitting into the tank. Use a borescope to visually inspect the bottom of the tank. The rusted part will usually be on the bottom and fairly easy to see this way. Most pressure vessels need to be inspected at 10 year intervals like propane tanks. You could then if suspicious, remove the compressor and fill the tank with water. Use a long hose and a hand pump to pressure it up to 200 PSI. Stand behind something in case it does rupture. If it passes that you should be good for a while yet. Just make sure to use water to fill the tank and in the pump. Use a good pressure gauge on the pump so you know what pressure you are at.Is there anyway to do a tank check at home other than a visual or "wait and see"? Ping test? Is there a life limit on tanks as there is on tires?
