sbh126
I recently purchased a 70 Dart Swinger with factory AC. Everything appears to be intact but the V2 compressor was removed for some reason but did come with the car. What do I need to do to get the AC system functioning and converted to R134A? I've read that the compressor oil needs to be changed to be compatible with R134A and the system needs to be flushed. Is that all there is or am I missing something? Should I leak check the system before put the 134 in? any advice is appreciated.
