G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Jan 24, 2013 #1 I have spent a little time searching with no luck. Could someone tell me where to look for a new cable for my 1972 Scamp /6. All stock set up
tekslk Well-Known Member Joined Dec 13, 2009 Messages 3,140 Reaction score 95 Location McClure, Pa Jan 24, 2013 #2 Try Rock auto .com
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Jan 25, 2013 #3 that is the first place i looked didn't see anything but i will look again Thanks
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Jan 25, 2013 #4 Looked again and then called Rock Auto no luck. Any other ideas
Darter6 Well-Known Member Joined Jan 16, 2008 Messages 6,202 Reaction score 4,286 Location Nevada Jan 25, 2013 #5 My local Car Quest had them. Got them for several Dusters and 1 Volare'.The Volare' is different where it clips into the firewall. Just for reference.
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Jan 25, 2013 #6 I will check with them. Any other sources?
rklein383 Well-Known Member Joined Dec 2, 2005 Messages 2,215 Reaction score 1,815 Jan 25, 2013 #7 My throttle cable for my 69 383-S Barracuda came off a mid 70's ramcharger 4x4. It was an exact match. Take your old one and go to the junkyard, if you have one, and look for one that works.
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Jan 25, 2013 #8 good idea I will check around
grumpuscreature Resident Curmudgeon Joined Mar 11, 2006 Messages 2,933 Reaction score 82 Location inabox Jan 25, 2013 #9 If it's any help, these folks will make one for you.... http://www.pentastarparts.com.au/store/
tekslk Well-Known Member Joined Dec 13, 2009 Messages 3,140 Reaction score 95 Location McClure, Pa Jan 25, 2013 #10 NAPA might have them, If you no the length I might have one off my 67 barracuda.
tekslk Well-Known Member Joined Dec 13, 2009 Messages 3,140 Reaction score 95 Location McClure, Pa Jan 25, 2013 #11 i just found thisonline check it out. http://www.theautopartsshop.com/auto+car-usa+parts/dodge+dart+accelerator-cable.html
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Jan 27, 2013 #12 I hope someday I know enough to help out like you guys do!!! THANKS
C Charrlie_S Well-Known Member Joined Oct 17, 2005 Messages 4,680 Reaction score 2,791 Location Silver Springs, FL Jan 28, 2013 #13 ATP has cables available for some mopars, also Dorman. http://www.dormanproducts.com/
416stroker Well-Known Member Joined May 14, 2006 Messages 864 Reaction score 186 Location Kalamazoo, Mi Jan 28, 2013 #14 I may have one that will work depending on length, if you don't have any luck finding one.
6pakattack Well-Known Member Joined Sep 1, 2005 Messages 2,443 Reaction score 77 Location Rockwell,NC Jan 28, 2013 #15 I've got one from my '69 Dart if that helps !!!
