yeah, with geometry loss probably .370
You do realize replacing only the head could actually hurt performance without a cam or intake change.I'd pick heads. That is where the real power comes in. The better cam combo you have the more you can take advantage the potential in the heads. Not saying it is the most cost effective but it gives a better base to work with. I've run "J" heads on a 273 with a 340 cam, and was surprised at the power level compared to stock heads and a 284 duration cam. Not even in the same league. At some point you run out of potential or driveability with a cam.
intake mentioned in the original post was a eddy performer with a 600 on top. And I think you can kill the engine with a cam swap very quickly without a converter and gear change. Have to be super careful with the cam swap....You do realize replacing only the head could actually hurt performance without a cam or intake change.
I’m not understandingSame as your bs
Example: Hughes Whiplash cam, designed for low compression enginesLow compression builds can still make decent power.
Correct cam selection play a lot.
And it's interesting to hear the comments about the 340 cam in a Teen. Some say you need a convertor and some say you don't. A higher stall convertor should help especially if you are having issues getting it to idle slow enough for gear changes from park to reverse and drive.Cam
Like the 340 cam:
430/444 lift
268/276 duration
Will work good with stock heads and the 600 on top.
As you know, a good convertor always helps. I've run the 340 cam in a 318 with a stock convertor. The cam still helped for sure, but maybe not felt from 0-30 mph.And it's interesting to hear the comments about the 340 cam in a Teen. Some say you need a convertor and some say you don't. A higher stall convertor should help especially if you are having issues getting it to idle slow enough for gear changes from park to reverse and drive.
This cam with a factory head will outperform a stock short block with a higher flowing head.Example: Hughes Whiplash cam, designed for low compression engines
Depends on what cam is in it now and what future plans may be in the stew pot. With stock heads the cam choices are restricted some. I would think go with a cam, even if the heads are the choke point. Then later the heads can be dealt with. Uncle Tony is doing up an engine using mostly stock parts. Yes, an aftermarket cam. Valves are being replaced in factory casting heads. Porting with DV and Unity Motorsports involvement. They are using the Carter 2 barrel carb also, so the build is a bit like a restrictor plate engine. Aluminium heads not allowed. Will be interesting to see the results as head work vids come out and the final dyno result.Per sake of the discussion, let's say the car is a '72 Duster, 318 with and addition of 600 eddy carb on a performer intake and 2.25" duals ran out the back from the stock manifolds. The car has a 904, and 3.23 gears. All in good working condition.
*WHAT MOVES THE CAR QUICKER IN THE QUARTER MILE?
- A hotter cam, any cam and lifter kit you can buy or have custom ground.
- A hotter head, any head is the option including trick flows.
- no other changes to the car can be had.
I take it you've never done it.This cam with a factory head will outperform a stock short block with a higher flowing head.
60', 1/8 and 1/4 mile and your favorite dyno too. lol
I call bullshit on anyone testing a head change only on a stock cammed short block.
Look at the flow increases .100-.400 on ported 318 heads, low 130's cc intake port small fast exh, then ponder milling them from 'open 68 .022 to 64cc' or 'closed style 66cc milled .024 down to 62cc'...Per sake of the discussion, let's say the car is a '72 Duster, 318 with and addition of 600 eddy carb on a performer intake and 2.25" duals ran out the back from the stock manifolds. The car has a 904, and 3.23 gears. All in good working condition.
I'm not doubting an increase from a head alone.I take it you've never done it.
You'll have to explain how it won't make power when it flows better at every lift with the same cam. For some reason.. I think even the tv crap shows have done it.
I have a truck with 311k on the stock short block that after tossing on some purpose ported heads feels like twice the engine it was.. and now rpms higher=hp why? It now has available 10-40cfm per .100 lift.. As for stock cam range/rpm...the valve springs are one of the main hindering factors of squeezing all RPM you can..and after running 50 years.....they're toast.
Stock teen runs 85 seat and 180 open, maybe . You need at least 250lbs open load to turn 5500 with .450 lift and not encounter spring spin/bounce boogaloo.
If the head can fill that same cylinder more per .100 lift and the Springs are upgraded to allow it to spin up and use the entire range of that cam 'which is a little bit more than it says' .....power increase.
I think the exhaust manifold will be the choke point . lolLooks we need to get out the dyno!
Depending on what other mods are done. My old 73 Challenger with a stock 340 didn't get any faster with just headers. Pretty disappointing to say the least.I think the exhaust manifold will be the choke point . lol
Here's a 4bbl xe262h cam and headers on a stock 318 long block makes 282hp @ 5000 rpmI'm not doubting an increase from a head alone.
I'm saying the right cam selection will produce more power up to a point over just a head change on a stock cammed block.
