Add partial throttle kickdown to my 65 904?
Transmission and Drivetrain Tech
  1. briwill70
    briwill70 Well-Known Member
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    9:00 PM
    Getting ready to pull my transmission to add a PTK. I have a 73 904 for parts and pulled the valve body. I think I read somewhere that some of the PTK valve bodies won't fit the early 904s. Is that correct? Hate to pull my transmission and discover that it doesn't fit.
  2. Hellrats
    Hellrats Just another dumbass FABO Gold Member
    1,297
    1030
    Jan 24, 2012
    N.E. Ohio
    Local Time:
    12:00 AM
    I'm not sure if it will work in that year transmission but I do know you don't need to pull the transmission out to remove the valve body
  3. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
    3,947
    1322
    Dec 27, 2013
    PHX
    Local Time:
    9:00 PM
    You need a specific part that torquflitepatty on eBay sells. I believe if you don’t it will be a waste of time.
    Jake
  4. C130 Chief
    C130 Chief Mechanical Genius
    3,063
    209
    Nov 23, 2005
    Boise, ID
    Local Time:
    10:00 PM
    Supposedly a 67 upper valvebody half is required. Is TF Patty still listing? I was under the impression that he had retired.
  5. Hellrats
    1,297
    1030
    Jan 24, 2012
    N.E. Ohio
    Local Time:
    12:00 AM
    Is TF Patty still listing? I was under the impression that he had retired?
    That would be bad! Got a lot of good stuff from there...
