Add Your Own Caption Part 91
Old Man Mopar
Righteous Dude
NW Ohio
Are those Spacely sprockets or Cogswell cogs????
I' trying to track down this loud gear whine coming from the front of the engine. Any ideas???
"My timing set is gear, gear, gear gear gear drive."
That looks like a question on a mechanical apptitude test I had to take once.
(If the crankshaft turns counter clockwise, which way does the top left cam gear turn?)
I intentionally missed that question because I answered "The same way as the top right gear" (a smartass even on tests)
The tester thought it was interesting that I answered that way, and I was right but still missed the question as far as the test went so I only got a 98% :)
The answer is clockwise BTW.
Mickey Mouse's inner workings... I always knew that little rat bastard was a Borg. you can clearly see the ears at the top.
Ya see...the top gear is connected to the conuter valve and the bottom one is hooked to the Johnson rod. The ones in the middle are hooked to pumps that keep the whole system filled with turn signal fluid.
