Has anybody done this ?.... i was going to install the Magnum force ties but torque box in the way?...i do not want the ones that cut up floor to add... thanks
If your car has torque boxes already you have to trim the subframe connectors to fit. The new magnumforce connectors with all that extra bracing probably will need significant modifications to work with torque boxes.
With most frame connectors that would work just fine. I think the magnumforce pieces would basically need the torque boxes removed to fit properly. But I’m just going off the photos on the website.
