hippy 60
How is the best and easiest way to adjust the valve on a 273 Solid lifters
Read up. There's many threads about the subject.How is the best and easiest way to adjust the valve on a 273 Solid lifters
We always did it running.How is the best and easiest way to adjust the valve on a 273 Solid lifters
You should mark your harmonic balancer for 90°. OK with all the plugs out if you want to find tdc on each cylinder.Just follow the chart.
How in the name of Buddha did you get the lash set correctly ?We always did it running.
Not as big a mess as you would think. And lots faster!!
This is how I do it on mine and it seems to work.Adjust lash COLD
Adjust the exhaust valves when the intake just shuts
Adjust the intake when the exhaust just opens
Chevy stud mount is a bit easier but it's really the same. Unless you set them running, the procedure is the same. Solids have to be adjusted from time to time.How in the name of Buddha did you get the lash set correctly ?
With a hydraulic cam I have done this and given them the 1/2 turn past quiet , but that was with stud mounted rockers.
Shaft mounted has to be an adventure.
Stock adjusters?How is the best and easiest way to adjust the valve on a 273 Solid lifters
Stock adjusters with after market cam comp cam.Stock adjusters?
I want to adjust them while i have the motor outStock adjusters?
