dgtwo
dgtwo
Does the push rod on a 1973 Duster adjust.my brakes seem to be sticking. I put a new booster on and master cylinder and prop valve. If so how do you do it?
Yeah I have disc brakes. Weird both would go at the same time. I’ll check the calipers and slides thank youI don't think they had adjustable brake push rods from the factory. You may have a sticking caliper slide or caliper piston if you have disc brakes though. You also might have a defective new master cylinder.
