Pretty easy to make a $6 NAPA pcv valve like this adjustable...
Just drill a hole in the plastic elbow and add a long screw to hold the pintle off the low flow position. Here's an exploded view of what's inside the above valve...
Here's where to add the screw...
Here's the view of the screw from inside the valve...
I pulled the plastic elbow off the above valve and installed it on a valve that had not been cut apart. Been using the same modified valve since May of 2013 with no issues, it draws 15"Hg of vacuum in a sealed crankcase @ 2500rpm cruise. I run 12lb oil rings on the street with 5W-20 Mobil1, without crankcase vacuum it went thru a qt in about 250mi. After sealing up the crankcase and adding the modified pcv valve, I might add 1 or 2 qts all summer. Lack of oil leaks is a huge upside as well.
Grant
