Adjustable Rockers looks like 2 types
How many of each are there?
I would be curious and do a ratio test on my engine and if one gave higher lift I personally would run that on the intake side. The biggest problem with those rockers were the insides. We banana grooved the shafts years ago to keep them from gulding on the shafts. Find the spec and check the inside diameter. Have fun and good luck.
Good idea, I am hoping there is only 2 different types of rockers and there are 8 of one type and another 8 of the other type.
That could actually be beneficial. If someone put 8 stock ones on the intake and 8 1.6s on the exhaust, for example. Depending on the camshaft grind, that could be adding a little power.
