72ScampTramp
Scamp Tramp
I have a new front suspension I put together. I believe I need to crank up the torsion bars to get the front end to hold its own weight. How far do you go in with the adjustment bolt? Car has no motor or trans but Im going to need to move it soon. Also on the pass LCA I see the lever in the middle is up a bit do I need to tap this to move it back down to meet the adjuster bolt and do I need to remove the torsion bar to do this?
