Adjusting windows
gtxdude
Bloomington, MN
Is there a way to adjust front windows on 65 Dart convert? I have shop manual and still can't figure it out :violent1: I'd like to raise the back of window to snug it up when top is down and align with back window when there up. (not very often) Not sure if the track in door can be adjusted or the adjusting nuts on door do the trick. I'll check back in the morn, thanks
